TwinTurbo.NET: Nissan 300ZX forum - yea, the 90-93 sprockets warp, causing a leak at the cam
JustinSCZ32
on December 12, 2009 at 8:58 AM
warping? No. And it's the '94+ are the two-piece type.
posted by LitlElvis
on December 11, 2009 at 10:45 PM
seal.
I've had this problem and solved a leak by simply replacing the Gear.
90-93 vs 94+ intake cams identify
nzryan
23:00:10 12/10/09
The nose is shorter on the later style
Broke_as_****
08:45:25 12/11/09
Re: The nose is shorter on the later style
nzryan
14:58:44 12/11/09
Are the 94+ cam gears less prone to warping??????
JustinSCZ32
14:59:26 12/11/09
Brett Dempsey would be the guy to talk to about that
Broke_as_****
16:59:01 12/11/09
LitlElvis
22:45:39 12/11/09
yea, the 90-93 sprockets warp, causing a leak at the cam -
JustinSCZ32
08:58:52 12/12/09
Re: yea, the 90-93 sprockets warp, causing a leak at the cam
JustinSCZ32
09:38:15 12/12/09
Your use of the term "warped" is misleading, and
LitlElvis
10:48:47 12/13/09
I have never found a "warped" VTC gear
LitlElvis
10:26:47 12/13/09
i have, but ima go sit down right now and not argue
JustinSCZ32
08:54:44 12/14/09
kfriberg
23:39:29 12/14/09
Yes and not that I know of (n/m)
Broke_as_****
00:33:19 12/15/09
Re: Yes and not that I know of
kfriberg
10:40:21 12/15/09
Not to my knowledge however
Broke_as_****
18:33:17 12/15/09
